The green LED is called the memory acces lamp. When you switch off the camera is will write back the last changes. when you switch the camera on and off, the light ususaly will stay off, because nothing has changed. When you remove the card en put in another the LED will flash again. At least my D7000 with 2 card slots will do so, because someting changed and the system will write that into the memory.
