Televison & Video Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The whole picture doesn't fit in the screen.
Mostly notice it when watching sports and cannot see the score and clock. I tried using the format button on the remote but it did not condense the picture enough. There are 2 settings on format- expand and standard. The standard has the better picture and the expand makes the problem worse. The picture is not distorted.
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Apr 09, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
Helped
16129
Points
116
If u are using a cable box there maybe a format button on that as well. So use it in conjunction with your tv format button to get a picture that fits the screen. Make sure no zoom format is selected
While watching sports my screen seem to be extended to where I cannot see the scores and who is leading in a race.
Use the remote control to ajust the picture format, which is currently in "expansion" mode.
or just switch to an HD channel and the problem should go away.
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
My picture does not fit the screen. It is as if it is zoomed in too tight. Scores and stats on sports are not visible on screen, etc.
This can usually be solved using the picture size function. Most stations that broadcast in HD now will have part of the screen cut off. On samsungs you can switch between the picture size being 'Normal' and '16:9'. Try both to see what works better.
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
The top of my picture is cut off.
Change the video output to wide screen
5helpful
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
My TV will not display the entire picture for my CABLE device
PUSH MENU AND THEN TRY VOL UP DN OR CH UP OR DN TO CHANGE SETIINGS
2helpful
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
