SOURCE: HEALTHMASTER 100, CAME APART IN 8 MONTHS.
I have been thru the fire about this! I sent my Healthmaster in recd another and it failed also. Almost always..it is the bearing that fails in the caraffe that supports the blade. The bearings that Jack Lalanne had installed in China..were not sealed...so they would allow water to enter corrode and eventually all of your blenders contents would come out thru the bottom! Or another thing that can happen is your blade will freeze up due to corrosion....and become immovable.
Jack Lalanne healthmaster is out of business. I manged to get a refund form Tristar..lalannes distributor..BECAUSE they authorized me sending my belnder back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up teh dough
So I doubt you can receive any money.
But this is what you CAN do!
1) If your motor functions well..you can buy a new carafe for 45 dollars or so from Cooking toys ( google cooking toys and it should come up)
2) OR if your cheap like me...and your blade doesnt rotate easily due to corrosion and your caraffe isnt leaking much...put a couple drops of oil on the outter rim of the bearing ( That would be located directly on the bottom of the outside of the caraffe..it surrounds the knurled metal part that is inserted in the motor for blending.
My blade was corroded and leaking a tiny bit..I put some olive oil on the bearing and it worked great! I have ben able to use my caraffe for a month now...when I expected to have to buy a new one from "Cooking Toys" Which I will do if this one fails.
3) If you buy a new caraffe form cooking toys..my advice? OIL THE BEARING WITH A LITTLE OIL...(any kind of vegetable oil) AFTER EACH TIME YOU USE IT! I SUSPECT IT WILL LAST INDEFINITELY>>>BUT TIME WILL TELL!
