SOURCE: Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
SOURCE: Warning light: Close print cartridge access door
It coudl be the document feed cover. The door on the rear or any part that can be opened and closed.
See paper jam in trouble shooting section of your manual. It shows several thing being moved.
Link to manual below:
http://h10025.www1.hp.com/ewfrf/wc/product?product=421991&lc=en&cc=us&dlc=en&submit.y=6&submit.x=3〈=en&cc=us
SOURCE: Access door to Photosmart 3210 is stuck open and won't close
I had the same problem. This is how I solved: I just spray WD-40 on the hinges and that's it, back in bussiness. Hope works for you too
SOURCE: My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
