How do you raise the water level in the bowl? There is so little water in there. We added water, but it fills up to the same level.
Thanks so much!
Becky Eisen
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
The toilet you just installed is a 1.6 gallon flush water saver and will not have the same amount of water in it that your old 3.5 gallon toilet had. The water level may not be able to be raised as this is the nature of the beast.
If you can raise the level it will only be a little and will be done in the tank area by increasing the water level in the tank. If the water level in the tank is at the mark provided it a done deal.
The amount of water refilled into the bowl is done by the tube that runs from the fill valve into the overflow tube of the flush valve so if you put more water into the tank more water will be put into the bowl but the bowl will only hold as much water as the trap weir will let it hold (what the factory has sit it at and is not changeable
