I have an older model brown stove and cannot light the pilot for the oven and unsure if i lit the b urners correct
i think its in the late eighties early 90's.
The oven pilot is accessible through the broiler door, (you're pretty much laying on the floor to light it) or through the oven bu removing the oven bottom panel. To remove the oven bottom, place fingers in holes near the door, and apply pressure to slide the bottom toward the rear, and lift when the front (by your fingers) comes free. Remove completely and set aside. You should now see a flame spreader (V-shaped metal pan) retained by one or two winged screws. Removing the screws allows removal of the spreader. This exposes the burner, complete with pilot. There is two tubing lines to the pilot assembly, one about 1/4 inch dia. and one much smaller. the one at the end of the 1/4 inch tube is the pilot. The piece at the end of the really thin tube is the thermocouple. You have to heat the thermocouple to get the gas to come on to the pilot. A match just won't do it as you need to apply a flame to the thermocouple for about 30 seconds or so. Heat the thermocouple until the pilot will self-sustain. When the pilot stays on on it's own, put it all back together. If you elect to just go through the broiler, again heat the thermocouple until the pilot will self-sustian.
