Question about Konica Minolta bizhub 161f All-In-One Laser Printer
Bizhub 161f driver - Konica Minolta bizhub 161f All-In-One Laser Printer
SOURCE:
Bubbabear64
  • 2794 Answers
SOURCE: Konica Minolta bizhub 161f remove fuser
Usually a fuser unit isn't a replaceable item by the end user. It requires a service technician to repair because they are wired to a circuit board and there are glass components in them that have to be handled carefully.
Posted on Jul 03, 2008
  • 121 Answers
SOURCE: I'm looking for a driver for a Konica Minolta
hi
you can download the software from the following link
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=832&filetypeid=0
Posted on Jul 07, 2009
taminol
  • 62 Answers
SOURCE: c14a3 error code konica minolta bizhub 161f
Hi jdt_mk,
Sorry to hear you have a C-14a3 code.
In my experience, this code spells disaster for the 161f.
The image reader has failed. The part can be replaced, but the cost would almost outweigh the cost of replacing the machine.
I have personally had to deal with two 161f with the same code.
Both times we changed the machine (because it was on contract).
Sorry it's not good news
Posted on Jan 29, 2010
xeerie
  • 347 Answers
SOURCE: Bizhub 161f will not turn on, there is only a
First of all check all the buttons on the panel.Any button should not be pressed inward. now strike gently on the lcd screen and panel.usually it becomes ok if not then call your tech rep because it will be complicated for you to handle such kind of job which you never did before.
Posted on Nov 16, 2010
xeerie
  • 347 Answers
SOURCE: Is it possible to set up a bizhub 161f with a host
No, you can enter only IP address.
Eror code M2
on a Bizhub 161f?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 23, 2014 | Konica Minolta bizhub 161f All-In-One...
Bizhub 161f will not turn on, there is only a bunch of rectangles on start up.
Jan 26, 2010 | Konica Minolta bizhub 161f All-In-One...
C14a3 error code konica minolta bizhub 161f
Hi jdt_mk,
Jan 13, 2010 | Konica Minolta bizhub 161f All-In-One...
Bizhub 161f not always answering an incoming fax...2nd try works but not always? Using the avaya phone system.
Avaya is a DIGITAL phone system, all fax machines are ANALOG. You nes a regular phone line for your fax
Jan 08, 2010 | Minolta BIZHUB 161F Black and White Copier
Can't get the scanner mode to connect
here is a simple and 100% working solution, if you cannot get the scanner mode, then no problemo, just open www.google.com now in search bar write, 'FREE DOWNLOAD IRFANVIEW" download irfanview from any link, now open irfanview by double clicking on it, now click on "FILE" tab, at the bottom click on "select twain source" as you select this option you will see a new box in which you see bizhub 161f is also shown, now select it from that list and press OK, now press ctrl+shift+A and press ok or enter. your bizhub 161f will scan the file and will save it in your computer, usually in c:/, check the directory where it (IRFANVIEW) is saving the file.
Sep 30, 2009 | Konica Minolta bizhub 161f All-In-One...
Getting 0048 error while faxing with a bizhub 161f
For the 0048 error code the malfunction is in the reception part and the possible causes of error is can`t receive correct signal after receive PPS_PRI_Q or PRI_Q,EOR_PRI_Q.
Aug 05, 2009 | Minolta BIZHUB 161F Black and White Copier
Jul 03, 2008 | Konica Minolta bizhub 161f All-In-One...
Konica Minolta bizhub 161f All-In-One Laser Printer Logo
56 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
