After pressing the start button and entering data (weight, level, time) the display will stay on until I start moving then the display shuts down within 3-5 seconds. If I don't start moving the display will continue to stay on until it switches to paused. I have checked for loose connections, the battery read 5.77 volts, the brushes are good. I am thinking the speed sensor, but I am not sure. Are the above symptoms those of a misadjusted speed sensor? Do they go bad? It worked fine in the fall, then sat for 3-4 months in the winter and now does not work. Thanks
I don't know about the answer, but I seem to have the exact problem!
I have a life fitness elliptical trainer X9i. This unit has a plug in power supply. I would think you should be getting a certain voltage to the console. Remove the plugs and clean them with alcohol. Call 1-800-351-3737 and ask for help from the manufacturer. I hope they are more helpful for you than they were for me. My console will not display the heart rate consistently, from the hand grips. They told me to clean the grips. Worked for one week and quit. I think the real problem is with the circuit board and they should help us to repair it. Need to find out who made the console board? Good luck let us know if you find the answer. I will be calling the manufacturer monday when they are open. Thanks
