I guess you have custom firmware. If so, you can use a pandora battery to solve the problem. If you do not know how to make a pandora battery or if this doesn't work send me an email or add me on [email protected]. But pandora is most likely to be the solution. I had the same kinna problem but I was updating it thats the only difference. The green light is on and the screen was blank and then the light turned off. So I used a Pandora Battery and it fixed. :P
i tryed to remove the battery and even switch it with another. and then i turn it on and the green light comes on but still no luck
