TP-LINK TL-WR642G Router Logo
Anonymous Posted on Aug 21, 2013
Tp-link tl-wr841n system light keeps on flashing, how do I fix it?
baha abu soude
Level 1:
Habit-Forming:
New Friend:
  • Contributor 33 Answers
  • Posted on May 29, 2014
baha abu soude
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
33
Questions
Helped
15991
Points
37
System light must flashing every second or one second . that is mean the system work correctely . but if the light was flashing rapidly , i think there is problem with system .
reset router , if the light keeps flashing , change the router
5 Related Answers
Anonymous
  • 99 Answers
  • Posted on Apr 14, 2011
SOURCE: Need help! Cannot access YAHOO
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Apr 21, 2011
SOURCE: need help on my TP-LINK TL-WR740N 150Mbps Wireless
Here's a GuessYa. Make sure you have the correct and exact DNS servers. If you screw them up, you'll be able to get cached pages, but new pages or functions will crash. It's a funny thing when you find it for the first time :-)
Carl
Ruben Tagalog Jr
  • 138 Answers
  • Posted on Sep 17, 2011
SOURCE: how to configure TP-LINK TL-WA730RE
you can get the manuals of how to configure tp-link tl-wa730re..just go to google and type free tp-link tl-wa730re manuals.
Anonymous
  • Posted on Sep 25, 2011
SOURCE: i have a TP-LINK TL-WR940N
I have the same problem. Some people says that its because of interference from other neighbors' wireless signals or any other in the surrounding etc.You can go to Router Properties and change the CHANNEL to 6 or 11 and observe any changes.
Anonymous
  • 477 Answers
  • Posted on Mar 08, 2012
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
2answers
I cant seems to be able forward ports on my TP-Link WR841N Router to view my cameras remotely. Pls can somebody help me with a solution. what should i do?
First, you need to know what's IP of Router and your Camera (or DVR). Then browse to IP of Router and setting up NAT port (or port redirect. If cannot you can give me your Skype, I will help you more then here.
1helpful
What is my WPA Key
It is on your router and is used to pair with a new Bluetooth device. Most are easy to find but my Belkin hides it in plain sight by placing it on a tiny tab next to the pilot light.
Network cable unplugged
Make sure that the cable is not plugged into the uplink on the router. That it is plugged in to a numbered port.
Can't connect to my router
try reset your router , and look at the status of lamps , then tell me that
Tp-link system light off
i think , you should replace your router , electricity problem
TP-Link TL-WR841N Wireless-N300 Router dropping connection
Do you experience problems with other WiFi hotspots?
I FORGET MY PASSWORD on tp link TL-WR841N
Most routers have a reset in the back. Hold it in till it cycles. This will clear all custom settings, and load defaults like new.
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
