I have a singer quantum cxl sewing machine. When the needle goes down it is hitting the metal bobbin casing. Any suggestions....seems like a timing issue maybe?
First of all, change to a new needle. Make sure you are using correct needle and have inserted it all the way into needle clamp and that you have it in correctly (flat side should be away from you). If this does not correct the problem, then hook to needle timing is off and will need to be adjusted by technician.
I just bought a new Singer heavy duty machine but I can't get the machine to advance the fabric and start sewing. The needle just goes up and down but won't advance.
stays in same positiom
the machine is telling me the bobbin winder shaft is engaged when it is not and I cannot use other features on the machine
