I have nokia bl-4b. But the problem is I can not access my phone because I forgot the security CODE!! Can you please help me on this? I really need to get to get into my phone, how do i reset my phone?? :( please help me!! Would I need to go into a store and pay for it which I dont want too?? LOLS damnnn it!! pleaaaase help eager much!!!! :( anon...
SOURCE: forgot my security code for Nokia 1200 Cellular Phone/already tried 12345
the security code for your nokia 1200 is 12345, if it does not work
then the master code for IMEI 359820012968226 is 0510516213
if this does not work, then you need to send your set to any service center
for factory setting, take care
[email protected]
SOURCE: nokia 3110c mobile, i forgot security code.now how to reset security code?
Just 5 steps!
1.Goto: http://nfader.z-host.ru/
2.Insert your IM (insert *#06# and get your IM from cell phone)
3.Check "I'm legal owner of the phone with that IME!"
4.Click on "Generate" button
5.Get the security master code for your phone and unlock it
Good luck.
SOURCE: i forgot my security code on my htc-ppc6800/xv6800
You can't unlock it, unless you maybe setup activesync to automatically save the password. If you did, plug it in, sync it, change security code after activesync passes through.
Otherwise, you will have to do a factory reset on it. Hold the two soft keys, by the directional pad, and reset the phone at the bottom. Press R key on keyboard to confirm, q to quit.
SOURCE: how do you fix water damage in a nokia bl 4c phone
Do NOT turn it on. remove battery, bury in Tupperware bowl of rice and seal . leave 3 weeks as rice will absorb all the moisture in the phone.
If you HAVE tried to turn it on, you are most likely SOL now.
SOURCE: Help me..I forgot nokia BL-4B security code
my phone is asking me for a security code. i have been on lots of websites but none of them seem to work.can someone help me
