SOURCE: Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
SOURCE: lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
SOURCE: belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
SOURCE: Belkin F5D9230-4 Wireless G Plus MIMO Router setup
To set up the router , you don't need the CD.
you can do it manually.
First make sure that your computer is able to go online through the modem.
If yes then connect the modem and the computer to the router and set up your router.
Click here for step by step solutions
SOURCE: belkin f5d8631-4 need to connect to sky but cant access config
you need the username and password from provider,then
Connecting to the Internet
To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
In order to change or to the wireless security page of your Belkin MIMO wireless router , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page .
3. In the left hand side, under the heading wireless click on Security
4. It will ask for a password to login, leave the password as blank and click on Submit, then you will be find the wireless security page where you can change or check your password
Good Luck!
Thanks in Advance!
With Regards,
Prema
