Computers & Internet Logo
Anonymous Posted on Aug 20, 2013
Typing in a electronic medical record online. the heel of my left hand hit something and my note disappeared. How can I "undo" the deletion?
Susain Khan
Level 1:
Habit-Forming:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 11, 2018
Susain Khan
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
Questions
0
Helped
110
Points
12
Hello, SISGAIN delivers the perfect EHR software solutions which make comfortable and spend less time on ethical record filling. The developers support with the best user-interface and feature-rich EHR integration services which will make easy to connect with clients. Take a look on our website: https://sisgain.com/ehr-emr-phr
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
403
Points
45
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
Un22f500 samsung tv calibration SAMMI JAMES AND JERRY SMITH ARE THE SAME SPAMMER
Electronics Appliances Tablets Laptops Phones TVs Samsung US
Visit this site to get more details from Samsung support. If you wish to get more details about its circuit and other, check Electro help
1helpful
How can I find and retrieve an email message reply that disappeared from the screen as I was typing.
Hate that. You might want to try hitting ctl-z right away. That's the keyboard command for undelete. My guess is that you're using a laptop with a mousepad. If so, you might be touching the mouse pad unknowingly and causing it to select text, then you're deleting it. It can happen so fast you might feel like a magician using slight-of-hand.
Feb 25, 2015 • hotmail.com
Windows 7 undo typing
you can just press Cntrl +Z it's an undo shortcut
Lost users manual for sumsung P1000
Please click on the link below to be able to access the manual of your samsung dvd-vr375 recorder/vcr combot thi
The exact manual for Samsung DVD-VR375 DVD Recorder / VCR Combo is not available but this is the best manual that fits in for your Samsung DVD-VR375 DVD Recorder / VCR Combo
http://www.samsung.com/africa_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=501&prd_mdl_cd=DVD-VR355%2FXFA&prd_mdl_name=DVD-VR355&srchword=DVD-VR355
paste the link in the url position and download the manual.
Hope this helped.
1helpful
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
9helpful
2answers
I want a free mobile theme
loads of free mobile themes can be downloaded from samsung mobile marketplace. simply open your phone browser and and search for samsung mobile themes from google site. Mostly you can download them for free from there.
Hope this solution has been helpful?
3helpful
Its slowing down and i want to reset everything were i could start off fresh
before you reset every thing lets do these steps
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
PS Please Note to leave a positive note.
3helpful
2answers
Slow running laptop
10.Update Windows
PS: Please leave a positive comment
To open pushchair i need to turn it upside down ,get on my hands and knees and make a complete fool of myself ,i must be doing something wrong.....please help
The best advise that I can give is the following:
Kneel behind the stroller.
Push in button 1 (the left hand-side) with the heel of your hand, whilst keeping this depressed, push button 2 with the heel of your hand, then whilst your hands are still pushing the buttons in, use your thumbs to push the frame forward - the buggy will then semi fold forward. Push the cross-bar between the handle bars away from you, this will release the elbow joint.
Then, simply push the pram toward the floor, this should fold the pram fine.
NOTE this does take a little practice, but if you stick with it, you will get it.
I hope this helps.
I cant play my videos
Probably you are not transfering files from the SAMSUNG MEDIA STUDIO 5, and the format is not compatible, so you are only carryng the file, try converting video to "svi" (this means samsung video) (default option in samsung media studio 5)
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
