SOURCE: Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
SOURCE: Knocking sound
Same problem here! How can I fix it? I'm in the middle of important Christmas baking!
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Testimonial: "Thank you for your post. I will check out the suggestionsl"
SOURCE: how to adjust bowl height on 20 qu hobart mixer.It
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
