I had the same problem, however I am also using VoIP which I don't think it matters. Solution: First, be sure you are using a 4-wire telephone cord (has the red, black, green & white wires on the end of the jack). Then you will need to add a DSL filter to the phone line between the wall jack and the fax machine. In my case, I plugged the filter in the VoIP box and plugged one end of my fax line into one end of the filter and the other end into the fax machine - fax slot. if you have a filter with multiple slots, be sure to plug it in the telephone line slot. As soon as I completed the process and tested the fax line it connected and worked just fine. I hope this helps.
First check a couple of obvious things:
Sometimes the presence or absence of a (DSL) filter on the line can affect fax reception.
Also check to make sure you have not enabled Fax Blocking.
Otherwise, I can only offer some information HP provides for support of VoIP fax setups, available by clicking here., and hardware setup options available here. Whether it is even remotely useful in your situation you'll have to judge.
You know there is also a Dell Forum where users
can pose questions and exchange answers. Have you checked to see if there are solutions posted there? Dell Forum 964fax error
I'm afraid I am not familiar with that particular machine or Vonage...sorry I couldn't offer anything more...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
exact same problem can send but can't receive fax
