Hello this is probably the most novice quiestion you'll ever get here but I want to mount my tv to the wall but theres a stand attached to it and the manual has nothing on how to disassmble it and when I look there are way too many screws to guess which one to unscrew without messing something up.
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
I havent tried it yet but Im gonna say thanks now and Im sure this is all I need at least knowing the wrong screw wont mess it up I feel better thanks again!
