I purchased a frigidaire front load dryer in 2003 and it is making a thumping sound with each revolution. Any idea what's wrong???
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Hit the start button, all the lights come on, but it doesn't go on....tried unplugging it...and sometimes it works....or letting it sit a while may let it work....what is the problem?
Have had the same problem with mine and it eats everything that has a small sting. It clunks when it starts eating. Peal the panties or sweat strings back out of the fron of the drum and it quiets down...Now, without warning, it locked up solid. This dryer is 2 years old. Extremely disappointed in this product at this point.
My dryer thumps with every revolution. Any help appreciated!
i have a frigidaire front load dryer model #le02152ee0 and the door handle has broken off.looking for part number and price
