Sony VAIO VGN-N130G/W Notebook Logo
A
Anonymous Posted on Aug 19, 2013
Sony Vaio VGN - T1XP Wireless network connection unable to renew and get ip address when trying to connect to home WiFi network. This happend last week just out of the blue. It was working normally on wifi up until then. 1. ADSL wifi modem router works normally with other wifi devices (other wifi laptops, android smart phones, black berry etc) 2. Re-installed latest wifi driver on laptop. 3. Hard formatted HDD and Re-installed windows xp-pro and SP3 and ran the updates using normal wired LAN which works fine. 4. Re-installed avast anti virus and firewall updates. 5. Tested laptop wifi in a public hot spot at airport and laptop wifi connects and works normally. 6. I created a MAC address list on the ADSL modem with the MAC of my VAIO and allowed it to authenticate with a new SSID on the modem. This worked for a few hours and then stopped working as well. Is somebody deliberately blocking my wi-fi on this device? Have I been hacked or something? Ran anti virus scans on desktop pc and laptop sharing this modem and nothing.... I am out of ideas and really irritated by now.
3 Related Answers
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2009
SOURCE: wifi connection
try plugging the wireless mouse receiver into a different usb port
reboot your machine
is there a key on the keyboard with a little wireless symbol? if so it is probably in blue and there is fn key that you need to hold down while you press the wireless key to turn on the wireless
Anonymous
  • 67 Answers
  • Posted on Jan 26, 2011
SOURCE: Recently bought a Sony Vaio
Can you try the laptop somewhere else? Try Mcdonalds or Starbucks, work, school, etc. Does it see the connection there? Does it connect ok there. Break your troubleshooting it into small steps. If it works else where then something is set wrong in your wireless at home. If it doesn't work else where then keep troubleshooting the laptop itself. When your watching the SSID show up then disappear are all wireless SSID also doing the same. Can you see neighbor and just watch if they drop in and out? Can you confirm your router is the same network speed. B,G or N. Make sure its a on a speed the laptop can do. Can you change your router and disable the security for a little while and see if that effects how the laptop connects. IF it works without security then check your security settings, Maybe the router is set to an old or newer type if security, Try different one's if it works correctly with security off. Can you login into your router and look at the logs its recording. Maybe there's a clue in it. Re-confirm the gateway and subnet are correct. I don't know if your XP, vista or 7, but open a command window or Dos prompt and type "ipconfig /a" It will list all the network information. Also type "ipconfig ?" For a list of options to use with the command. You may need to a release or renew the connection.
Testimonial: "Offered solutions that I haven't thought about"
General Systems Consulting
  • 5051 Answers
  • Posted on Apr 26, 2012
SOURCE: wifi not working on my sony vaio vgn-nw270f
make sure you turn the wireless switch on. It should be on either side or the front of the laptop.
Did you configure the new router and set the wireless on it?
If your internet provider is a phone company such as AT&T did you configure the router to be PPOE (and set the userid and password) and bridged the modem that goes into the router?
If your internet provider is a cable company did you set the router to be DHCP?
Does the Sony even see the wireless network in the View Available Wireless Networks list?
Did you put the wireless key in correctly?
You didn't by chance happen to hit the FN function key on the lower left portion of the keyboard + the key (F1 thru F12) that toggles the wireless on and off? The correct F1 thru F12 key to hit will have the wireless signal icon )))) or it will have the icon of a tower with the wireless signal )))).
I tried to connect my vaio to wifi it is showing limited axcess what should i do
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Laptop won't connect to wireless internet
wat is the Ip address
default gateway
????? Fast reply needed for a quicker resolution
1helpful
2answers
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
WiFi works fine, but no internet
please open a comand prompt and try to release the ip and renew the ip. check is the Ip changing.
or
turn on the DHCP in your router.,. so the router will give an ip to you pc
SONY VAIO VGN-NR21Z DOESN'T SEE WIFI
Be sure that your wifi button is ON
Be sure that your wireless network is working
Check your wireless router settings
Check if you see any other wireless network available on your computer
Test connection, see if you pulled an IP address
  1. Go to the Windows desktop
  2. Select Start then Run
  3. In the text box type: cmd (WIN98/SE type command)
    At the command prompt type: ipconfig
4. What does it read as the IP address?
* If it reads 192.168. something dot something then you are pulling
an IP address and are connected to the network. The problem is
software related, check your firewall, and wireless card configuration.
Also check any WPA or WEP encryption keys. Check with the respective
manufactures.
* If it reads 0.0.0.0 for the IP address you are not connected to the network.
* Check your connection configuration and the adaptor.
* Check with the respective manufactures.
STEP TWO/ Basic troubleshooting continued....Testing the adaptor
1. Go to Windows desktop
A DOS window will open.
4. At the prompt type: ping 127.0.0.1 (reserved IP address for all adaptors)
5. Check the line that reads "packets sent = 4, Received = 4, Lost = 0
A. Zero is good, the adaptor is working. Again check the connection
configuration,and the adaptor configuration.
It may be a power issue especially with older or less expensive computers
or wireless cards.
* Check the antenna location, are you inside or outside, look for interference.
B. If it reads all 4 packets lost, the adaptor is not functioning.
* Check and update the drivers, Contact the respective manufactures.
* If it shows any number of packets lost (you are dropping packets)
it is an adaptor or signal strength issue (generally form the laptop side,
not being able to reach back) especially with older or less expensive
computers or wireless cards.
* Update the drivers
* Check antenna location, or distance from the signal
* Contact the respective manufactures.
Can connect to IP address through router, not internet
Have you look at your wireless router setting on the router ?
Try pinging yahoo.com and see if you get any reply. Make sure the right gateway/ip is on your laptop.
2answers
Vaio laptop VGN-BX540B user
you should only need to enter the WEP key and get youre friend to remove your mac address. You may also need to refresh the ip address of your wireless card, so go to control panel>network connections>right click to properties>TCP/IP line>properties and ensure 'obtain ip address automatically' is ticked, then reastart your pc. Or you can also click Start>Run, then type ipconfig /flushdns, so as to renew your dns and ip address.
you may need to run the network wizard, as your sony may not be set up as using a gateway type connection and may be instructing other pcs to connect via itself and not on the network.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
