Question about Haier Refrigerators
I have a Haier hnde03vs. The freezer works but the fridge doesn't get real cold. Is there a fan in this unit? If so, how can I access it?
    New Friend:
  • 43 Answers
There is a fan in the freezer its whats keep your refrig cold there is a flapper that goes from the freezer to the frig maybe its shut off and needs to be opened more ..Also make sure there isnt any ice build up in your freezer if its not defrosting everything will ventually warm up
Posted on Aug 19, 2013
SOURCE:
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Freezer very cold fridge warm.
the freezer circulates air through the refrigerator by using a fan every 24 hours the defrost timer comes on the compressor goes off and, the machine defrosts if your mullion defrost heaters are getting hot
and, staying hot you have miss-wired your defrost timer
Posted on May 25, 2009
  • 9 Answers
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Posted on Jul 09, 2009
  • 22425 Answers
SOURCE: I have a Haier model HTE14WAAWW refrig. with top
check the fan in freezer sounds like it is stuck [iced up ] or needs to b lubed at the back of freezer will see fan feel if fan is blowing or just humming
Posted on Sep 24, 2009
Why does my refrigerator turns off restart a couple days later ?
Could be the back of the freezer is not defrosting and is packed up with ice. The cold air then can't circulate to the fridge part as the fan is frozen solid in ice. Had this happen due to a faulty transducer that tells the defrost system the freezer is iced up and to go into defrost mode. Also it could be the fan that blows cold air down into the fridge from the freezer compartment.
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
Refrigerator turns off restart a couple days later haier hnde03
the is an electronic timer for defrost mode on all frost free frig/ freezers it goes bad to find that in your frig call the manufacturer or a good repair man
I have a 3.3 fridge/freezer-the back wall of the fridge has a buildup of ice ???
Sounds like either: 1) The thermostat is set too low.
2) The defrost control is bad
3) The main drain in the freezer has frozen over not allowing water to drain.
Jan 29, 2013 | Haier HNDE03VS 3.3 Cu. Ft. 2 Door...
I have the Haier HNDE03Vs 3.3 cubic foot dual refrigerator. I notice that there is some water accumulation as well as some/few icicles in the refrigerator section. The water tends to pool towards a hole...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Haier HNDE03VS (32 cu ft) Compact...
Freezer gets cold fan dont work fridge dosnt get cold
The fridge relies on the freezer fan to supply it's air flow. If the unit is running and the freezer fan is not, then most likely it is the evaporator fan motor that has failed. You can access it by removing the inside back wall of the freezer. If you need help get me the complete model number out of the fridge and I can pull up the breakdown to help walk you through it.
Jun 14, 2010 | Kenmore 65802
My fridge is not cold, but the freezer on the top shelf works perfect. What should I do?
Since the freezer has the greatest demand for cooling, there is a fan which distributes some of the cold air through the fridge; this fan has likely failed.
When you hear the compressor running, hold your hand inside the fridge near vents in the back of the upper shelf. If you feel no air circulating, the fan is bad.
Not knowing your unit, I'm not sure how you access the fan motor, it could be from the back or from inside one or the other compartment.
The fans are not expensive but the labor can vary a bunch depending on how tough it is to access the fan and the area in which you live. I would call their service center after you have checked as described and state that the fan has failed and needs replacement. Ask them for a quote or at least a 'not to exceed' price.
Mar 18, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Not keeping things cold
check to see if the compressor is running in a cycle. if the compressor is not cycling, you will need to replace the compressor and fan.
if the compressor is humming, it because of a faulty motor and relay(start device). replace the compressor unit in this case.
May 22, 2009 | Haier HRF10WNB Top Freezer Refrigerator
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Apr 02, 2008 | Haier HTQ21JAAWW Top Freezer Refrigerator
Refrigerators Logo
208 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
