SOURCE: My acer aspire 5920 will not power on!
Hi
Thanks for using FixYa. You will need to reset the Laptop
if it is not starting up. Follow the procedure as under to reset it---
Remove all connections to and
from the laptop. Now remove the battery and press and hold the power on button
for 2 minutes. Release the power on button. Slip in the battery pack. Plug in
the power to the laptop and to the wall. Please do not plug in any other
devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
SOURCE: Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Testimonial: "Exactlt what I had been thinking!"
