The projector was being used about a week ago, when a loud like almost power surge noise occurred. Now when the projector is turned on, the image comes in fine however, there is a very loud almost fan like noise that shakes the case causing the image to be fuzzy. There are no warning lights on and about 1000 hours on it.
SOURCE: Dell 3300MP Projector
my advise is to get a new one or try ebay - i got my dell 3300mp NEW in box for under $400 - and have looked at other projectors there are very good deals on ebay but make sure you read the entire listing
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
SOURCE: projector
Same problem
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
SOURCE: projector
Hi
If the fan is not working, the lamp will not fire. Kindly make sure that the panels are seated properly. Also chek if the outer cover is seated back 100% as if that is not seated back 100%, the unit will not work.
