Question about Necchi 3102 Mechanical Sewing Machine
Does the Necchi "Royal Series" model 3205FA have a stretch stitch?
SOURCE:
SOURCE: Have a Necchi 3205FA and
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
Posted on Dec 06, 2008
  • 41 Answers
SOURCE: Manual for Necchi Royal series model #3205FA
I could not find a free, PDF manual. But I did find this manual you could purchase for about 15 bucks.
Posted on Feb 26, 2010
  • 980 Answers
SOURCE: I have a Necchi Royal Series 3205FA. I wanted to
If you have a stop motion dial with little grooves all the way round the best way is to get a wide plade screwdriver, put the plade part on one of the grooves on the left hand side of the dial and give it a thump on top with your hand, that usually does the trick.
Posted on Mar 07, 2010
  • 255 Answers
SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Posted on Mar 15, 2010
SOURCE: the needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Posted on Jul 29, 2010
Necchi heavy duty royal series. Manuel says 3205FA and 3204FB. I want to know where to oil it. I also need help because it won't reverse anymore. Any advice?
It's an old metal mechanical machine, right? It is probably seizing due to old oil that has dried. Here's my method for "unfreezing" old sewing machines. (You won't believe how good it sounds and how nicely it runs after you've give it some TLC!)
Wheel on right side that controls the needle up and down is very tight...
Jul 04, 2018 | Necchi Sewing Machines
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
Nov 06, 2017 | Sewing Machines
Im trying to see if I can fix the upper tension spring on my Necchi 3205fa machine. I think it was stretched out of correct shape.
If the spring doesn't revolve easily while it catches the thread it may be. To see what the shape should look like you can go to Ebay and type in "Necchi 3205fa sewing machine tension control". This should give you some very nice photos. You may even want to purchase one from Ebay and replace the one you are having problems with.
Oct 04, 2016 | Necchi Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
Necchi royal series
I agree there is something wrong with the necchi royal. you didn't say what the model number is, I would suggest taking the machine to a repair shop that fixes necchi sewing machines and have them check the machine to see what's wrong with it,, it may be just something minor, I also have a necchi royal myself and they are good machines.
Aug 25, 2013 | Sewing Machines
Locate blind stitch on necchi royal series
need a manual or just a picure of necchi CM501
Oct 18, 2012 | Sewing Machines
I have a Necchi Royal Series 3205FA. I wanted to wind my bobbin. I could not loosen the Stop Clutch Knob. This is a NEW sewing machine. It isn't a strength problem. The part will not turn.
Feb 21, 2010 | Sewing Machines
Necchi 3102 Mechanical Sewing Machine Logo
358 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
