Question about Rio EX1000 CD Shelf System
Need RIO EX1000 Power Supply Board.
The power supply board (AH41-00411A) on a RIO EX1000 that I've acquired is dead (lightning). I repaired it the first time, but then another power surge did even more damage (the previous owner had disabled the fast-acting fuse circuit which I did not have a chance to replace). Does anyone know where I can find a replacement power supply board? New or used would be fine. Heck, even a schematic would help! It's a pretty good music player so I hate to just trash it. Thanks in advance. Bob
  • BobFixIt May 07, 2008
    Hello, Guest!
    Thanks for writing! I would love to help you with your problem, but I cannot locate the component that you referenced. There does not appear to be any such "AR51" on the power supply board (mine is Rev 3). In fact, there are no "AR" components at all. Most of the resistors are designated as "RR," and I couldn't find anything with a "51." Can you be more specific as to where it's located?
    Also, if you have the same unit and power supply board, would you be able to provide me with the resistance values (color banding) for RR3 and RR4 (they are what needs to be replaced on my board). Both are located directly behind the two large capacitors, next to the a large transistor heatsink.
    If nothing else, perhaps we can both help each other! Thanks again!
    Regards,
    Bob
  • Allen wells
    Allen wells Nov 25, 2018
    In circuit value of RR3 .22 ohms. RR4 is .002. Colors, RR3 is Red,Red,Blk,Slvr RR4 is red,red,gold,gold . I took pictures so email me if you want them. Smoketest@hotmail.com.
I don't have any solution for your problem BUT you can resolve mine : what color are the rings of the AR51 component (next to the big dissipator)
Regards
Posted on May 02, 2008
SOURCE:
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
NO POWER, ONLY 6 MONTHS OLD, HAD POWER OUTAGE A WEEK AGO- EVER SINCE THEN TV WILL NOT TURN ON.
if you suspect lightning or a power surge that caused the problem, if it were lightning could have effected the power supply board, or if it was lightning it could have went in on the cable or antenna connection. to narrow down the problem, check the fuse on the power supply board, if that is ok then with a volt meter check and see if there is 5V volts going to the signal board, that is the board with the antenna connection, one of the plugs that go to the board probably has writing next to the wires in the plug, if no 5V probably the power supply board bad, I almost forgot, when you take the back off look for burnt parts. if you have the 5V going to the signal board now the problem could be signal board or power supply.
Jul 07, 2014 | Vizio L32 32 in. LCD HDTV
Dynex tv
If your TV dead after the lightning, then your TV doesn't power ON with red light stays on lit you possibly have faulty main board.
If totally no indicator try to replace the fuse on power supply board if busted or blown (it is usually connected directly from power cord.
If the fuse still blown you need to replace the whole power supply board.
please rate!!!
Dec 05, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
Emerson TV Model #LC401EM2F Fix after lightning?
Lightning damage on LCD TV's can be a doozie. You really need to get it checked out by a qualified technician. I've repaired several TV's hit by lightning, most of the time the damage was limited to the power supply board. However, it is possible that multiple boards were damaged. If multiple boards were damaged, it's not worth repairing the set.
Jun 02, 2012 | LG Televison & Video
A couple of days ago lightning struck really close to my house and now my tv doesn't work. I've opened the panel on the back hoping that since it was struck by lightning that it just got...
At least look at the main AC fuse (F1) in the power supply module, and also look to see if any of the MOV's has blown.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 03, 2011 | Sanyo DP26648-R 26 in. LCD TV
Lightning struck nearby last night and our VISIO HD TV will not turn on. The stand-by light comes on, but that is all. Is there hope for it? Is there a chance it can be repaired? It was new in Feb....
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will helpout in solving the problem....
May 17, 2011 | Vizio Televison & Video
Tv struck by lightning and will not turn on. Can it be repaired or is it a lost cause?
Yes,it repairable.The tv have power at all like the LED power light indication flashes?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.No power LED light indication all.The power supply board is dead and also the Tuner signal board is dead.Must replaced both boards.
Oct 16, 2010 | Polaroid FLM-3232 Television
The green led blinks 12times. local repair guy guy said somthing about taking out the y.
Power LED blinking it about 90% power supply board is dead.The other 5% are both boards some time are dead.The power supply board and the Tuner siginal board is dead.Replaced the power supply board it ur best bet to get power back.After power is back should get picture too.Not than the Tuner board also need it replaced.Tries Websites Shopjimmy.com,Ebay.com for boards parts.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
Every time i switch on my tv, nothing happens. After i,ve powered up about ten times then it starts ok. this is,nt right surely!!!!!!
Ur tv power supply board have these dead parts call capacitors,they have leakages of gases,they bulges up on it top or puff on it top.These capacitors are dead,must be replaced to get the power supply board to be working normal again.U know basic electronic's,know how to do soldering?U have tools,soldering iron,solders?Seaches out these dead capacitors,that are gases leakages bulges up on it top or puff up on it top in the power supply board,that the board where the power a/c cord go into it,that the power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2009 | ViewSonic N4060w 40 in. LCD TV
LIGHTNING HIT IT
This could be bad.. You want to check the fuse in the power supply. If you are lucky that is all that is bad. If the lightning got thought the fuse you could have real problems. You would have to replace at least two boards, one being the power supply board and the other could be the signal board or digital board. Sometimes they unitize the signal and digital boards as one board. Lightning can do strange things. sometimes it will just take out a diode and fuse Sometimes it can trash a set making it cost prohibitive to repair.. Good luck.
Jul 24, 2008 | Televison & Video
Rio EX1000 CD Shelf System Logo
121 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
