Question about Life Fitness 9500RHRT Recumbent Bike
Life fitness C9i exercise bike display won't come on when pedaling. There is no battery in this bike.
5 Suggested Answers
SOURCE:
maxtreadmill
  • 832 Answers
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Posted on Apr 17, 2010
SOURCE: Life fitness recumbent bike problem
Hi
We had exactly the same thing. If you take the covers off you will find a black battery pack in the bottom. It is about the same size as a cordless drill battery. We got a replacement from Maplins - cost about £10. It works perfectly now.
Posted on Jun 17, 2009
SOURCE: DOA Life Fitness 9500rhr exercise cycle
You should check your battery-it must be putting out at least 6 volts to get the computer started up-depending on the era there will be a battery near the bottom frame-you will need to remove on of the side covers to reach it-
Posted on Dec 30, 2009
ercupa190
  • 12223 Answers
SOURCE: need user manual for Life Fitness G4
Please go to website from Lite-Fitness:
http://www.lifefitness-latinamerica.com/commercial/support.html
in this web page you will download your user manual for free, please give you model, serial, etc, and ready.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA
Posted on Nov 26, 2011
Looking for location of battery in LifeFitness C9i exercise bike. (C7i battery was in control panel, earlier models may have been in the base.) Thanks!
How do replace the battery in Lifecycle C9i exercise
The web site above states the following:
The 9 volt battery for the display on the bars of the bicycle goes in underneath the display (on the bottom of it).You can also see the 7th page (pages are not numbered, simply scroll to the 2nd to last page) of the manual at the link below to see where the battery installs:
https://www.lifefitness.es/static-assets/document/manuals/C9iAssemblyInstructions_12-07-05.pdf
Feb 16, 2018 | Exercise & Fitness
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
Bike display won't come on no matter how much you pedal. What is the problem?
Just change the battery in the head unit Cher. It is not powered by how fast you pedal :>)
Dec 29, 2015 | Flaghouse Sportsart C520 Recumbent Cycle -...
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
How do I remove the pedals on a 8500 life fitness recumbent bike
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Dec 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Life Fitness 9500RHRT Recumbent Bike Logo
3,101 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
