TCL L32HDM11 32 Class Widescreen LCD HDTV - 720p, 1366 x 768, 16:9, 30 Logo
A
Anonymous Posted on Aug 19, 2013
How to adjust of brightness and color of my tcl tv L32d10 model.
2answers
How do I adjust the "Brightness" on my 20 year old Model TXJ 2566 Samsung TV?
Hi Norman Malkin, to adjust the brightness of your Samsung TV, you must enter Menu, select Image, display a list where Contrast Brightness Color and other parameters appear, select Brightness and increase or decrease the brightness to your liking, you may need make Color and Contrast adjustments
I hope you can adjust it
Greetings Franco Dosil
Hola Norman Malkin, para ajustar el brillo de tu TV Samsung, debe entrar en Menu, selecciona Imagen, de desplegara un listado donde te aparece Contraste Brillo Color y otros parametros, selecciona Brillo e incremente o disminuye el Brill hasta tu gusto, puede que necesites hacer ajustes de Color y Contraste
Espero lo puedas ajustar
Saludos Franco Dosil
I need a universal code for my TCL L32D10 LED TV cause my TCL Child lock is on and i dont have a remote for it.. i just baught a universal remote
0038,0031,0036. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
1helpful
I need a solution,,,my tcl tv displays no signal
Have you try to check the brightness and contrast adjusting?. If yes then the problem still exist my suggestion is to bring it to the repair shop to prevent further damage of your tv. Just a thought thanks.
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
2answers
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
TCL TV picture too dark
try turning the light sensor off
Problem with the color on my TV
I will need to know what make and model your tv is.
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
