John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
A
Anonymous Posted on Jan 26, 2018
L130 A john deere mower . Tower bearing went out . replaced complete tower assembly. deck belt started slipping. replaced belt with new John Deere belt. belt still slipping . replaced tension idler spring, same results. replaced electric clutch same results. Belt idlers do not appear to be worn .
Wade Mobley
Level 3:
  • Master 513 Answers
  • Posted on Jan 29, 2018
Wade Mobley
Master
Level 3:
Answers
513
Questions
0
Helped
275180
Points
1079
If it is fully tensioned then double check all idlers and blade mandrels. The other thing that happens even to factory technicians is belt in pulleys i've seen technicians put belts on and not be on pulleys do to slipping off when installing on pto clutch.
mburke3
Level 2:
Sergeant:
  • Expert 459 Answers
  • Posted on Jan 26, 2018
mburke3
Expert
Level 2:
Sergeant:
Answers
459
Questions
5
Helped
91534
Points
629
Sounds like the wrong size belt or pulley
check routing of the belt also
3 Related Answers
agent91
Ned White
  • 2100 Answers
  • Posted on Jun 10, 2010
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Anonymous
  • 1627 Answers
  • Posted on Jul 29, 2010
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Anonymous
  • Posted on May 03, 2013
SOURCE: How to change the Belt on a John Deere L130 with
why cant i get simple routeing diagram for the belt on john deere l130????
1helpful
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
John Deere L130
I have not worked on these lawn mowers but there is plenty of posts on different lawn mower sites on how to rebuild the John Deere L1xx series transmissions. I would suggest have a read of this site. It also mentions the parts required and the cost. I understand these lawn movers use the K46 transmission system.
TuffTorq K46 Repair Guide with Pictures
Aug 15, 2014 • Garden
I have a L130 and after it warms up it starts to whine and won't go up a hill.
Is the belt going tight enough when the drive is engaged make sure it is not slipping or you may have a rear drive problem.
2answers
How to change the Belt on a John Deere L130 with 48" mower deck? Is there a Belt diagragm that show proper routing?
Try the John Deere parts website https://jdparts.deere.com or give sullivans a call they are a john deere dealer and are garden machinery experts they will be able to explain to you what to do. you can find their contact info on their website http://www.sullivansgardenmachinery.co.uk
15helpful
I need a belt routing diagram for a John Deere L130 riding mower. Deck belt, 48" cut 23 h.p.
If you go to this page http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO , scroll down the left side to the heading for your deck.
2helpful
I need to run the mower deck belt on my john deere L130 lawn mower and would like to know if there are any diagrams for that
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
May 16, 2010 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
