Posted on Apr 08, 2009
CAN NOT FIND DETAILED USER MANUAL FOR CAR GPS-NAVMAN S150
HELP TO FIND ? CAN NOT FIND DETAILED USER MANUAL FOR CAR GPS-NAVMAN S150 (N214)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
563
Points
Try this link http://www.google.com.au/url?sa=t&source=web&cd=2&sqi=2&ved=0CCEQFjAB&url=http%3A%2F%2Fwww.navman.com%2Fdocs%2Fmanuals%2Fnavman-s-series-spirit-smartst2009-manual-en_gb.pdf&ei=21UdTfiHHIncvQO62O3YDQ&usg=AFQjCNHk5RJKs_2kTgl6BuCZktoWj04CgQ&sig2=3Sk2TQy7rkno4l5ZL12-mw
My Navman S100, Model N214, has a loose power connection at its base (one too many shoves into the glove compartment). I need to open it up to see if I can solder it, but after the 2 small screws, I'm...
To open the unit there are 4 screws, 2 are on the base. There are also 2 on the back at the top that are hidden by rubber plugs. Remove the plugs using a small flat screwdriver. Once the screws are all removed use a small screwdriver or butterknife to slide down the side and the back should pop off.
I have the same problem with mine, but the USB connector seems to go straight to a board, so don't know if can be tightened, soldered or otherwise repaired.
Can you tell me where to obtain a car cradle to hold my sat nav to car window i have a navman series n214 mobel thhamks
I hope the picture below is what you're looking for. I got that on Amazon online. Here's the URL for you to order it. http://tinyurl.com/4sksgd3
2helpful
Navman operational problem
If you can get to your settings area it looks like a little gear. Go 6 options down and touch it and you should be able to change it there. The user manual is in the link below if you need more technical information.
http://www.navman.com/in-car/3294/Australia/Navman-Australia/Our-Products/Current-Products/S150/
Jan 03, 2009 • Navman GPS
8answers
 Grubhead
Grubhead
SmartAviator
SmartAviator
