Microwave Ovens Logo
A
Anonymous Posted on Aug 18, 2013
My hotpoint microwave oven grill combi model mwh221 is running but not heating up.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 25, 2007
SOURCE: Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Anonymous
  • 184 Answers
  • Posted on Mar 27, 2008
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 20, 2008
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 09, 2008
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 06, 2008
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
I have a lamona combi microwave 7150 how do I set it to microwave only everytime I set it the grill light comes on as well.
To cook with microwave only, press "Microwave/Grill/Combi", once, the screen will display "P100". Press "Microwave/Grill/Combi" to select the power level. Then press "Start/+30Sec./Confirm" to confirm and turn the dial to set cooking time. Then press "Start/+30Sec./Confirm" to start cooking on microwave only.
To switch to microwave/ grill combination cooking, choose C1 or C2 when selecting the power level.
See page 14 and 15 in the user manual.
WHEN I SUBMITTED MY PLEA FOR HELP TO GET A MICROWAVE USER/OPERATOR MANUAL, I WAS ASKED: WHAT MAKE IS IT?
that model is from the uk,you need to search over there for it,i just searched for an hour and come up with this, Accumetrics Inc Announces United Kingdom Distribution Agreement With...
22l is how much it holds,not the model number,Elitech commercial grade steam oven/combi grill - in VGC - not used a great deal, but a very handy addition to any kitchen at busy times!
Voltage - 220-240 V input 1650 watt when on steam mode, 1250 oven/grill mode.
Dimensions 220x315x312 mm
Manual available online to download - (Ref Elitech EA053747)
Capacity 22L Instruction Manual Copy ELITECH Steam Oven Combination Grill Model Ref...
WHY DOES THE COVECTION OVEN AND GRILL DOES NOT WORK IN COMBI OVEN
NN-ct559w set on combi micro/ grill function , micro low , grill 1 but grill didnt come one, tried grill on own again no grill . Can thiis be repaired?
1helpful
Hotpoint Microwave oven Model RVM1435WD will not heat up. It will start and the fan runs, but will not heat any food,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Basic Microwave Oven Troubleshooting Tips
heatman101
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
1helpful
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
