I am trying to add the front seal on a Kenmore HE 2 plus clothes washer. I have removed the old seal but I can't see how the new one can fit. It is exactly the same as the seal I took out it doesn't seem like there is enough room to put the entire seal in. It was difficult to pull out even after I removed the seal rings. My worry is that I can't get the seal on tight enough or in the right place. Is there any tricks to putting it on right?
It's a tight squeeze, remove the lower panel and tilt the machine back to get better access. Once the seal is in place and the seal rings are on, tug on it slightly to make sure it's well seated. Test it with a fill and let it agitate for a few minutes while looking inside the lower panel access to check for leaks (keep some towels handy).
Let me know if you need more assistance.
