Breitling Navitimer A2332212 G5 431A watch Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keeping 2008 breitling cockpit watch running
I had a new watch that stopped 4 hours after I took it off from a week's worth of wearing. Must I wind the watch 40 times to get it running and then wind it every few days or is it suppose to be self winding after 40 turns?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Apr 08, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813854
Points
13579
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
1helpful
Watch flashes--why?
Flashing means low battery. Time to replace it.
2helpful
Bulova Millenia 100 m,stops running,move it to wind,starts up
When you say "wave wind" do you mean you're waving it around to wind it with the self-winding mechanism? If so, that will only keep it running briefly as you're experiencing. Manually wind the crown about 40 turns clockwise to "fill the tank" and wearing it daily will keep it topped off. Anytime you don't wear it for a day, manually wind it again. As for the cleaning, the inside of the watch doesn't get real dirty but over time the lubricants wear out and thicken which makes the watch run slowly or not as long as it has to work harder to move the gears through the thickened lubricant. A watchmaker can disassemble and clean the old lube out with solvents and then reassemble the watch with fresh lubricants.
Apr 27, 2010 • Watches
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
2helpful
2answers
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
1helpful
How long does watch run after winding
35 hrs if you do not move it at all. If you wear it continuously you will never have to wind it again!
Breitling watch winder rotations requirments
The watch should last 36 hours from fully wound. If your wearing the watch and using a watch winder and its still stopping, you have a problem with the mechanism. Get it serviced. (its probably just a clean and oil req'd)
2answers
Breitling navitimer watch
breitling navitimer, keeps perfect time on the desk, but when ion the wrist it runs fast, as much as one hour in 24 hrs
2answers
Wrong time
Your watch is an automatic watch which means it winds itself as long as you are wearing it. If you don't wear it for several days it will stop working. To solve this situation buy an automatic watch winder to keep your watch in while you are not wearing it and it will keep the correct time.
3answers
Rolex runs down
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Top Breitling Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Breitling Watch Expert? Answer questions, earn points and help others
