SOURCE: Im forget my pssword bios, i Tray to open bttrey
remove cmos battery either notebook battery for 5 minutes. Connect the 2 pins for few seconds (NOT the battery), put them back and let's try....
SOURCE: reset password bios acer 4315
This can be done by visting vendor website.
Please download the BIOS update utility from the following web site. You need to select you machine model number under BIOS button u can get the utility to download.
SOURCE: I have IBM thinkpad z61m, & forget bios password
IM ZOE BOY(509) AND I LL LET U KNOW HOW TO DEAL WIT DAT SMALL ISSUE IF UR LOCKED OUT AND ONCE YOU TURN ON UR PC ITS SAYS ENTER PASSCODE THATS THE EASIEST THING EVER HERE IS UR ANSWER:
1_DISCONNECT THE NOTEBOOK FROM THE POWER CABLE
2_GO ON THE BACK OF UR PC LOOK FOR THE BIOS IT LOOKS LIKE A WATCH BATTERY
3_REMOVE IT FOR LIKE 30 SECOND THEN PUT IT BACK AND TURN ON UR PC BACK ON
P.S MAKE SURE ITS UNPLUG AND WITHOUT THE BATTERY CAUSE WE DONT NO POWER AT ALL DURING THE PROCESS..........
U LL BE ABLE TO GET ACCESS WITHOUT ASKING NO DANM CODE BUT IF YOU HAVE TIME PRESS F2 TO RESET IT WITH YOUR OWN CODE NEXT TIME IT TURNS OFF U DONT HAVE TO WORRY A BIT.
IF U R NOT LUCKY U MIGHT FIND ANOTHER LOCK AFTER PASSING THE BIOS THAT A PERSONNAL ONE GOHEAD DO UR THING LET ME KNOW WHAT GOIN DOWN WHEN FINISH WITH UR HOMEWORK.....
ZOE BOY=HAITI,PORT AU PRINCE.
SOURCE: my acer model number ZG5 not login windows i
Hi, pravingoud89 The only thing you have to do is restart "Safe Mode". Reboot and start pressing F8 many times until you get the Windows Advance Menu. Select Safe mode, then after you see the logon screen (dont get scare about the things you see) you will find your user account AND the Administrator. Select the Administrator (usually doesnt have a password) and then go to Start - Control Panel - Users - select the user and click remove password. Restart normally and done!. I hope it helps and dont forget to rate and provide positive feedback for our free support today! Thank you :D
SOURCE: The bios for my acer laptop is grayed out and can
You can reset the bios by jumping the header plugs within the computer, another way you can do it is by removing the small single cell battery from inside the hardware itself (not the one that charges the computer) Most modern day computers don't have the battery, so you may need to remove the battery that does hold the charge for the computer itself if it's integrated within the hardware and not a big bulky one that sits in the bottom of the laptops casing.
I hope this helps :)
