Nintendo Wii Console Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to reset my wii system? - Nintendo Wii Console
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Apr 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
2470
Points
13
There are 3 ways to reset,1.press the reset button on the console.2.go to the last page of settings and press system reformat.3.eeek.pull the plug out for 5 minutes.and plug it in again.
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Apr 08, 2009
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073068
Points
27242
Here is how to reset your Nintendo Wii:
1. First, the easy way. A soft reset of the Ninetendo Wii. If you Nintendo Wii has just started acting up and there is no reason to perform a hard reset then follow this instruction. Simply press the reset button and hold down for 2 seconds on your Nintendo Wii Console.
2. Now, for the more advanced hard reset. Interestingly, the Nintendo Wii has NO hard reset facility to be accessed through the machine or via buttons. The ONLY way to hard reset your Nintendo Wii is to UNPLUG it for 5 minutes. Once it is unplugged it resets itself and your badly behaving Nintendo Wii should be restored.
Note: By hard resetting the Nintendo Wii, it will not delete any information on the SD Card that is used for storage. If you wish to delete this data, stick it into a computer with a multi-media card device or a digital camera and reformat it.
Wii nintendo bought used how do i reset it
Method One: The Soft Reset The soft reset is the easiest way to reset the Wii, and the least intrusive. There are two ways to perform the soft reset, either using the Wii remote or the button on the console.
To reset the Wii using the Wii remote, begin by pressing the home button (the small button with a house on it). This will bring up a menu screen. Next, move the cursor to the button labeled "Reset" on the screen. Press the "A" button on the remote to select the reset option. This will reset the system.
If the Wii remote is not responding, users can also reset the Wii using the button on the main console. First, locate the button labeled "Reset"--it's on the front of the console, beneath the "Power" button. Press and hold the "Reset" button for two seconds, then release the button. This should reset the system. Users should remember that resetting the Wii will shut down any running programs immediately and destroy any unsaved data, so only reset the Wii if it is causing problems. However, resetting the Wii will not alter any information stored on SD cards.
Method Two: The Hard Reset If the soft reset doesn't fix the Wii, users can also perform what's known as a "hard reset." A hard reset involves disconnecting the Wii's power supply and must be done manually--there are no pre-programmed buttons on the Wii that will perform the hard reset.
To begin the hard reset, find the "Reset" button on the front of the console. Press it for two seconds, then release (this performs a soft reset on the device). Next, press and hold the "Power" button. Continue holding this button until the light in the button switches from green to red--this means that the Wii console has shut down. Now, unplug the AC power adapter cord from the wall outlet or surge protector as well as from the console itself. Allow the Wii to remain like this for five minutes.
Once five minutes have passed, plug the AC power adapter cord back into the console, then connect the other end of the cord to an AC outlet. Press the "Power" button to turn the Wii on. The system should now be running smoothly.
Method Three: Reset Factory Controls Sometimes, Wii users might want to return the system to its original, factory-shipped status and remove any personal data. Nintendo especially recommends doing this before selling or gifting a used Wii to someone else. To perform a factory reset, also known as formatting the system memory, go to the Wii menu and select the "Wii" button, then select "Wii settings." Click on the blue arrow on the right-hand side--this will bring users to a page called "Wii System Settings 3." Select the option labeled "Format Wii System Memory," entering the parental controls PIN if requested. Finally, select "Format" to complete the factory reset. This will remove all hard-drive data from the Wii, and such data cannot be recovered, so users should only perform a factory reset if they're sure they want to do so.
Master key for parental control
  1. Navigate to the Wii Menu by pressing the HOME button on a Wii Remote and selecting "Wii Menu."
  2. Look at the date and time displayed on the Wii Menu and ensure they are correct. If incorrect, they will need to be changed in order for you to complete the PIN reset process. You will not be able to reset the PIN until the date is correct.
  3. Select the Wii Options icon in the lower-left corner of the Wii Channel Menu.
  4. Select "Wii Settings."
  5. Click on the blue arrow to reach the Wii System Settings 2 menu options.
  6. Select "Parental Controls," then "Yes."
  7. Enter your PIN or select "I forgot."
  8. Answer your secret question or tap "I forgot."
    • If you know the answer to your secret question, enter it to unlock parental controls. The system will go to the change parental controls screen and you will be able to change your PIN.
      • Be sure to enter the secret question exactly as you originally typed it, as the answer is case sensitive.
    • If you don't know the answer to your secret question, tap "I forgot."
  9. A screen will appear showing you a request code.
  10. With that request code, you will need to do a request that involves charging US$0.50 from a credit card, to confirm that you're an adult. Or should your kids try to circumvent your parental code, it will show up on your credit card bill.
You can request the reset here:
Parental Controls PIN Reset Nintendo Support
If you need further instructions on how to do that, simply look here:
Forgot Parental Controls PIN Wii and Wii mini Nintendo Support
Parental cantrol
Or get a more detailed step-by-step instruction here:
I have a new router and need to know how to reset it to my wii
What to Do:
Look at the date and time displayed on the Wii Menu and ensure they are correct. If incorrect, they will need to be changed in order for you to complete the PIN reset process. You will not be able to reset the PIN until the date is correct. How to
The screen below will appear.
Make a note of the inquiry number displayed on your system. You will need it to reset your PIN.
Click here to reset your Parental Controls PIN.
An e-mail address is required to use this service. If you are not able to provide an e-mail address, please contact us for additional assistance.
for more help visit CBR Tech Solutions
Forgotten password
If there's no way for you to retrieve the password the last resort will be the hard reset to be able to access your game console
Here
Knowing how to reset a Wii allowsyou to move quickly from video game to video game. You can reset your NintendoWii from your Wii Remote or on the actual system, depending on which you preferand if your Wii Remote is actually working. Luckily, resetting your Wii fromeither the system or from your Wii Remote is an easy process.
Instructions
1 Start playing a Wii game. In orderto reset the Wii and go back to the main Wii menu, you have to be playing avideo game. Click on the game you want to play and allow it to boot up. Onceyou are done playing the game, you can reset your Wii.2 Press the "Home" Button. Located onthe Wii Remote, it is a button between the "+" and "-"button with a picture of a house on it. This will bring you to a menu thatallows you to reset the video game that you are playing. You can only accessthis menu when you are playing a game.3 Press the button on the actual Wii. You mayhave to reset your Wii from the button on the system if your Wii Remote is outof batteries. Simply go up to your Wii and find the button that is nearest tothe top of the system. It will be the button that is lit up. Press the buttonand your Wii will reset.
Please follow the instruction and it will resolve the problem .Thhank you and have a great day
3helpful
My wii was working a few days ago then I tried to turn it on today and it will not come on. I tried plugging it in to different outlets but it still will not come on. No lights will come on either.
hello,
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Try to find someone with a Wii.. not that hard everyone has one. See if they will let you use the power cord.
test the cord and if that doesn't you know its inside the Wii.
Then, their are fuses inside the console one of them my have blown.You need a special screw driver.
Hope this will help..
6helpful
My wii stopped working all of a sudden and i don't know whats wrong with it. I've reset it and unplugged it and it still won't work. The light is just off and I didn't do anything to it! Is there another...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
If it's not working, you can get a *new* NINTENDO brand AC adapter at the following
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} store.richspsxparts.com/wiiredvddr.html.
Beware of cheaper knockoffs around the internet.
My wii after trying to run homebrew channel doesnt have power
You probably just need to reset your Wii's power cable. This happened to a lot of people I know.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
