hi,
Check the tray loading belt of your cd player. If the loading belt is over sized then this problem can occur. Normally the loading belt will become over sized after a few years of use according to the weather condition. . If so the loading tray will not go inside fully and will not engage with close sensing switch. if so the it will open automatically without any external command .Normally in all players the loading belt will be under the loading tray near the frond side of the mechanism. check the same. keep the player in eject position remove power and then try to replace the belt.
ok
You have to load the software from the installation CD BEFORE you plug the Go Gear into the computer. Go ahead and unplug your mp3 player, load the software, then replug it.
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
I have a gpx mw3847 and I load songs by opening up My Computer, finding my gpx mw3847 and opening it. Then I go to MY Music where I have my MP3 songs and just drag or copy the ones I want over to my Player. I don't use Windows media player to load songs no any of my players
