GE WDSR2080D Top Load Washer Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our GE top loading washer will not drain the water out, it just hums. Our washer is about 10 years old so maybe we just need to replace it but hope not. Thanks for any suggestions/solutions. Sherry
Anonymous
Level 3:
  • Master 686 Answers
  • Posted on Apr 08, 2009
Anonymous
Master
Level 3:
Answers
686
Questions
0
Helped
248982
Points
1652
POSSIBLE BAD LID SWITCH CHANGE THAT FIRST.
Sm8280871 is the model listed under the lid. It is a Roper by Whirlpool top load washer about 10 years old. I can hear the motor however the washer does not spin, or drain. It appears that it tries to...
I suspect the V belt is worn out try taking the side cover off you would have to tilt the machine another helper maybe needed make sure you drain the remaining water out and unplugged the cord safety first
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
AGITATOR
Water gets drained when it passes the washing cycle on the knob ? do you hear the motor humming ? like it wants to start? if no sound from motor then check the sensor switch located under the top of washer where door closes, it could be loose or defective, if you hear sound coming from motor , check the belt ,if belt OK, then MOTOR need to be replace, hope this info helps , AJ
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
2answers
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
2answers
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
