SOURCE: Clutch pedal does not disengage clutch
If the car hasn't been driven for a while it could be corrosion on the fork but I think that is unlikely. I think you are right about the release bearing being jammed in the spring. If the truck has quite high mileage, it probably means a clutch job.
SOURCE: 1987 nissan pickup- clutch worked fine one day,
sounds like your clutch master cylinder or slave is no good. do your self a favor and replace them both if you are going to be replacing them.
Testimonial: "Thanks, I'll give that a try. Mike"
