Heating & Cooling Logo
Anonymous Posted on Aug 18, 2013
Swinging motor not working - Heating & Cooling
Anonymous
Level 3:
  • Master 379 Answers
  • Posted on Aug 18, 2013
Anonymous
Master
Level 3:
Answers
379
Questions
0
Helped
106335
Points
1009
If you have chosen the right mode the it is very probable that it needs cleanin...
If 75 landy Hitachi track hole. My swing motor,manifold union center is leaking. I would like to know how to fix it myself. Or how much it would cost to have someone to fix for me.
Hitachi Deere Excavator Center Joint / Rotary Manifold ...
? 10:00
https://www.youtube.com/watch?v=Vsd_Os6WFCw
Mar 12, 2013 - Uploaded by woodieswood
Hitachi Deere Excavator Center Joint / Rotary Manifold Rebuild ... my Hitachi landy swing brake keeps ...
Viewing a thread - Hitachi Excavator- Swing motor gearbox leak ...
talk.newagtalk.com/forums/thread-view.asp?tid=362837...flat...1
Jan 30, 2013 - 3 posts - ‎3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
Se280lc-2 Samsung excavator hydraulic motor and swing motor are not working
main pump is faulty, swing switch faulty, swing brake stuck or activated, swing motor bad, filter clogged.
The Bright stars swing is not working anymore. We put in 4 new D batteries but the swing does not have the same power? What can we do?
You'll probably need to replace the motor in the swing. Most of these types of swings work off a motor with a plastic gear attached, and the inside of the gear gets worn down over time. The motor still gets power and still turns the gear, but the gear doesn't have the grip that it used to so the swing doesn't move as much (especially with a baby in it).
1helpful
My LG art cool a/c blades in the vent arent swinging (from left to right)as i keep pressing the swing key on the remote.. please help
In some models, there are swing and sweep motors. Swing will work the vent up and down. Sweep or air flow motor will work for louvers left to right. If sweep motor not works replace the motor. If no sweep motor option, you have to direct by manual only. Be care ful, when you are doing manually, switch of the unit. Thanks.
I bought the swing for my daughter and put new batteries in. Music works but it won't swing at all. What is wrong? I hate that I spent 60 dollars on something that doesn't work.
It's likely the motor gone bad. The contacts inside the motor can get burnt out and prevent the motor from turning. Did you buy the swing brand new, or was it used? If you bought it new you should return it for a refund.
1helpful
Swing is not working at all
are the linkages to the swing motor broken?
is the swing motor working?, if not then it is either the swing motor switch or the motor its self
4helpful
2answers
Baby swing......graco doesn't swing
I had the exact same problem the motor worked fine but when we took it apart the gear inside was stripped. i hate saying it but best thing you can do is buy a new swing. i personally recommend http://www.toysrus.com/product/index.jsp?productId=3420749&camp=PPC%3A204318389. its a little bit high but so worth the money. my 8mo old baby girl loves it. it also has a AC adapter so no more batteries and an ipod hook up as well so you can pick what music you want your baby to listen to. best of luck.
Mar 29, 2009 • Baby Gear
318helpful
28answers
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 • Baby Gear
Top Heating & Cooling Experts
Paul Carew
john h
