Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
The fact that the neutral light does not show up on the dash may indicate that the gear position indicator is not calibrated correctly. Does the bike start with the clutch pulled in?
Press the [MENU] button, then press [#, 1, 0, 1], enter the current month, date, and year with by selecting two digits each, ex. 03 11 14, press the [OK] button, enter the current time, ex 11 47, then press the [AM/PM] softkey button. Then press the [SAVE] button.
Matias,
Try using the Intelligent Power Software Suite (IPSS):
http://powerquality.eaton.com/Products-services/Power-Management/Software.asp
If you are trying to monitor the UPS, use Intelligent Power Manager (IPM). If you are trying to shutdown the Virtual Machine safely, use Intelligent Power Protector (IPP).
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT"(bottom right arrow) - display should read "lines" 4.- Press "SHOW" (top right arrow)- display should ask for a line number 5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001 6.- press the show key (top right arrow) 7.- The display should say Trunk/line data 8.- Press "show"(top right arrow) - display should read "trunk type" 9.- Press the next key (bottom right arrow) 7 times" 10.- the display should say "trunk mode: unspr" 11.- Press softkey "CHANGE" to "super" repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
