Watches Logo
A
Anonymous Posted on Aug 18, 2013
Croton cn307287 I just bought a Croton Aquamatic wrist watch. the serial number on the back reads CN307287 but when I look it up on the Croton website it cannot be found. It is a stainless steel watch with an orange rubber band. Can someone help me at the least find an owners manual for this watch.
1helpful
I have a 2003 Croton Belagio watch How do I set correct date?
To set the date on your Croton Belagio watch, you will need to follow the steps for setting the date on your particular watch. Every watch is different, so the specific steps will depend on the make and model of your watch.
Here are some general steps that you can follow to set the date on your watch:
  1. Locate the stem (the button on the side of the watch) and press and hold it until the display begins to flash. This indicates that the watch is in time-setting mode.
  2. Use the stem to cycle through the different settings, such as the time, day, date, and year.
  3. When you reach the date setting, use the stem to adjust the value to the correct date.
  4. Once you have set the date to the correct value, press the stem to exit the setting mode.
If you are unsure of how to set the date on your watch or if you are having trouble, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Croton customer service for assistance.
I need to know where to find the serial number on a Croton Chronomaster watch.
Serial numbers are always in the back of the case or on the movement. Take to a local jeweler.
Vintage Croton Watch: Identification and Value Guide
Valuable Antique Detector https://www.txantiquemall.com > vintage-croton-watch
Model/Serial Numbers. The easiest way to identify a fake is to check its serial numbers and run a quick search online to confirm if it's a genuine model or not.
‎How To Confirm Authenticity of... · ‎Value of Vintage Croton Watches
Anyone know how to tell when a Croton watch was made?
WATCH TALK FORUMS https://www.watchtalkforums.info > threads > anyone-...
Dec 8, 2011 - I would suggest getting the caseback opened and find out what movement is inside and enter the number into the search box of Roland Ranffts ...
Missing: Chronomaster ‎' Show results with: Chronomaster
How do I remove links
Not too difficult...check out this video on Youtube
https://www.youtube.com/watch?v=NfxCJp9HyjM
I need to change the batteries and i cant get thhe back off
mcdevito75 here, Croton, a high quality watch, Best Bet is to look for a small watch repair shop in your area for the battery change, these quartz movements can easily be destroyed with mis-handleing and anyway a battery lasts at least 1 year.
I lost instructions on how to set this watch can you help me? (aqua sport)
mcdevito75 here, Here is Croton"s Contact information, 800-443-7639 9 AM 6 PM EST.
I have a Croton watch. It is a automatic.I can't get it to run.I was informed that the watch had to be wound. The crown{stem} has four settings.I shak it and it runs for about 15 seconds
In the first position (closest to the case but not screwed down if it's a screwdown crown) wind the crown clockwise about 40 turns and it should run fine. The automatic winding system relies on wrist movement to spin a weighted rotor that winds the watch. When you're not wearing the watch or not moving much when you do have it on, it will run down and you have to manually wind it to get it going again. If you wear it everyday and are reasonably active you may never have to wind it but take it off for a day and you will.
Can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Croton automatic watch, band problem
Unless you have the appropriate tools for the job, it is likely that you will mark or damage the links taking them out yourself - any reasonable jeweller will be able to perform this service, normally only costing a few dollars at most. You could also return the watch to Croton to get this done if you prefer; http://www.crotonwatch.com/contact_us.aspx If you are still determined to do it yourself, then it is fundamentally just a matter of identifying the removable links (they will have a small screw head visible on the side), buy the correct size screwdriver(don't get a cheap one, it will do your watchstrap no favors) then it is simply a matter of unscrewing the link pins required, reassembling the pin where you wish to rejoin the strap - use loctite or similar to keep it from undoing, but be careful not to get this in the moving parts of the strap. if you can post a close up picture of the removable links from all sides, then i could talk you through it in more detail. Hope this helps :)
Top Croton Watches Experts
vince
ADMIN Andrew
ADMIN Andrew
Swetha Jagga
Are you a Croton Watch Expert? Answer questions, earn points and help others
