Saeco Easy Espresso Machine Logo
Posted on Sep 06, 2007
Blinking red light
The red light on the front of the machine blinks all the time, even though all the components are in place. I have tried removing them and replacing them with the machine on, so please don´t suggest that. Also, sometimes (even with the blinking light) the hot water comes out and sometimes it does not. I guess i should mention that at first the brew unit would not fit back into the machine, so I opened up the machine and turned the dial from the inside until the brew unit fit back into place. But the red light still kept on blinking.
  • 1 more comment
  • TedG Dec 09, 2007
    Red warning light continuously flashes. I have performed all the usual tasks that the instruction book says to do. When I power up the machine it makes all the “usual” sounds but when I press the brew button nothing happens and the red light continues to flash. I have primed, cleaned & changed out the water to no avail. All appears fine. Is there any way that the machine be reset ?
    Thanks, Ted Gawloski
    [email protected]
  • jrn11 Jan 21, 2008
    what loose piece??
  • Anonymous Mar 25, 2014
    tried to open grounds drawer while unit was running and now maching wont turn on, red light on, and cannot remove the brew ubnit
Lex2
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 20, 2008
Lex2
Contributor
Level 1:
Answers
Questions
0
Helped
663
Points
Aha! The lose piece was indeed the problem. Getting it reattached was time consuming, however. I spent about 5-7 hours today trying to get everything apart and get the piece put back on.
In the future, I will be more gentle with this machine, especially when putting the brewing unit back in after rinsing it out. (Do rinse it out, by the way, about once a week. Otherwise the quality of coffee you get will gradually get worse and worse.)
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 20, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
798
Points
The blinking light is a warning that something is not right.
-It will blink when the espresso waste basket is full. sometimes they stack up funny and it appears full and light blinks.
-second the beans don't always fall into the grinder from the hopper. They just need a gentle nudge
-Third it may be low on water.
-Four if you don't push the door closed on the fromt and ensure the spout where the coffee comes out is pushed in to the reciever inside the door the light will come on.
For me it has always been on of these four things.
Once I got the hang of the little nuisance everything works great. I love my machine and would buy another.
I have one or two espresso's a day,
2answers
Why do i have a red blinking light on my motor when its in off position
Probably washer is smart enough to detect the out of balance.
Try to distribute the clothes in a balanced maner as soon as you detect it is out of balance.
2helpful
2answers
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
1helpful
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
1helpful
Sony W580i won't turn on. Blinking red light.
It turns out i found a solution to my problem. All you need to do is wait a few days and every day try turning it on several times. Mine turned on with 2% power. If you don't see the red light blinking then you probably need to charge it up then turn it on.
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
3helpful
RED LED BLINKING WHILE CHARGING THE BATTERY
It is normal. Just push both sides of the charger in. It happens all the time.even though it might stay blinking its normal
Red light far right blinking continuosly (#26)
Hi jason,
The flashing red light indicates tha _something_ is not positioned correctly. Please check and see if you can find the sensor(s) that determine whether or not the components are correctly positioned.
You might also try unplugging it for 10-20 minutes to allow any electronic sensors to reset when you reconnect power.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
