SOURCE: belt on nordic track exp 1000 not moving
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
SOURCE: how do you adjust or tighten the belt on the
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
