Printer goes through motions to copy doument but pages are blank
I changed the black ink as per prompted to do, both cartridges are seated well, proceed to print as usual and it operates as if to copy
and print but pages come out blank. checked document, is face
down, tried printing in black and white, still blank sheets.
Re: printer goes through motions to copy doument but...
From Kodak's website:
Question :
Why are prints from my all-in-one printer blank?
Answer :
There may be multiple reasons why your prints are blank. To resolve this problem, we have an easy Step-by-Step Solutions and Repair tool.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below: 1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab. 2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page. The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps. If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below: 1. Please open the "Solution center" again and go to the "Maintenance" Tab. 2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer. 3. Get a damp paper towel. 4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 6. Next dab the cartridge on the towel to make sure that the ink is flowing. 7. Snap the cartridges back into the printer. 8. On your computer, select "Old Cartridge install." 9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
If it goes through all the motions like its making a copy but the page is blank you need a new print head or cradle with new ink cartridges. Ink printer do not like to sit for long periods. It will cost about 60.00 from canon.
Steven 818-888-0006
Check whether you removed the yellow strip of the cartridges. remove the upper unit and check when head cleaning the ink goes throw the ink tube. if not you can sure that the head cleaning unit is to be repaired.
I have a lexmark x2740 printer and have recently replaced the ink cartridge with a genuine lexmark ink and now my printer wont print, it goes through the motions of printing but only a blank page comes out.
Some of them do. Try going into the printer properties and disabling bi-directional support. This will not allow the printer to check. HP has set some printers to not function if its disabled, but hopefully yours is not one of them.
I had the same issue when I replaced the printer and kept the old cartridges I had just purchased. The OK button I pressed was on the PRINTER not the PC. You dont say the model printer you have. Mine is an all-in-one J6480.
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
