Canon PIXMA MP780 All-In-One InkJet Printer Logo
Posted on Dec 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Pixma MP780...the 3eBK cartridge won't print.
Everything was working great until I had to change the 3e cartridge. I followed all the instructions (have never had a problem before) but can't get the 3eBK to print. Have cleaned the heads to no avail. I thought maybe the cartridge was ''bad'' so I put in another new one and it too will not print. Any ideas for me?
  • Anonymous Apr 09, 2009
    same problem with the 6e as well as the 3e, it will print color, but won't copy black and faxes come through blank. How do you clean the print head?
Jon Slaton
Level 2:
Habit-Forming:
New Friend:
  • Expert 47 Answers
  • Posted on Dec 02, 2017
Jon Slaton
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
47
Questions
0
Helped
10521
Points
141
I cleaned my print heads 7 times before it all cleared up. Another possibility is there may have been a piece of clear paper or sticker or something on the replacement cartridge - take the cartridge next to it out and compare the two to make sure they look the same.
5 Related Answers
Anonymous
  • Posted on Jul 27, 2007
SOURCE: canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Anonymous
  • 30 Answers
  • Posted on Feb 08, 2008
SOURCE: PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
I can tell you that the MP780 does not know the difference between a BCI3 and a BCI6 cartridge so there is definitely another issue.
Anonymous
  • Posted on Jun 21, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Anonymous
  • Posted on Jul 26, 2008
SOURCE: won't print from 3ebk cartridge
I take new head - dont work. I put old head from my son`s pixma ip4000 in my Canon MP760 and printer is working!!! Put new head in his printer and don`t work. Problem is with new printheads, THEY DON`T WORK. I change 8 printheads and they work well, but last two printhead (brand new) DON`T WORK. I live in Serbia and I can`t do anything because Canon in Serbia don`t accept problems, they simple said : out of warranty. Maybe you can ask in some other country? I pay 100Eur per printhead here.
Anonymous
  • Posted on Aug 17, 2008
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Black 3e won't print, even with NEW printhead.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
I changed my Canon PIXMA MP780 3e cartridge, and
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
2answers
Won't print from 3ebk cartridge
i think there is problum in ur cartridge cas adoptor , clean cartridge circuit plate and put cartridge then try
4helpful
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
1helpful
2answers
Kind of an X-file situation there. You should try an other cartridge, maybe that one is defective
Canon Pixma MP780 Printer - black 3e fails to print
installed a new Print-Head, but that was no changes. I use refill ink, and it seams the BlackInkTank is not exactly on the Printhead and it is Air in the Pipe, i take the Printhead and the Ink-Cardridge in the Bathroom, and press the Ink-cardrige on the Printhead and take a hard breath and blow in the Air-Holes of the Ink-Cardrige until black ink come out of the Printhead, reinstall in the Printer, end it works well.
sorry about my bad english
old marine
old marine
ZJ Limited
ZJ Limited
