Kodak EASYSHARE M1063 Digital Camera Logo
A
Anonymous Posted on Aug 18, 2013
Lens error 102 - Kodak EASYSHARE M1063 Digital Camera
2answers
How Do I Fix Mac Error Code 102?
The Mac error 102 happens when there are issues with the Apple Store, Mac App Store, firewall problems, and ian ncomplete installation. When the operating system error code 102 occurs on your system, some files may have gone corrupted and results in iTunes issues.
2helpful
Lens error.102 showes up when turned on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
1helpful
My daughter's Kodak easyshare c613 gives lens error 415, 1, 1, 102 and the zoom in function doesn't work. Can we fix this?
In my experience when there is a 'lens error' there is internal damage perhaps from dropping the unit and it is fixable only by the Kodak.com website's authorized service center.
http://support.en.kodak.com/app/answers/detail/a_id/19879
1helpful
En la pantalla de mi camara digital kodak c140 sale un error de lente error 102 por favor decearia que me expliquen por que salio este error y como solucionarlo les agradecere mis correo es...
Error de lente sinifica que hay un problema en la extension or retraccion de la lente. La placa base detecta que la lente no se puede mover y hay tienes el eror de lente.
Lo unico que se puede hacer es intentar ayudar suavemente el movimiento de la lente mientras que se encende o apaga la camera. Si esto no sirve, llama Kodak al numero que se encuentra en el manual de uso.
Aqui ay un artculo que trata el problema (en Ingles). Los codego son los de una camera Sanyo, la situacion es la misma que se encuentra en Kodac con error 102.
Hi. If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 pro
Sep 04, 2010 • Cameras
1helpful
Urn off the camera and I get error 102 lens can I D
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
12helpful
2answers
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
3helpful
2answers
How to fix kodak c140 lens error 102
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thanks for using FIXYA
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
