Nitin m patil,
Wireless Switch
Wireless Technology
Wireless Switch LED Settings
The LED (located on the Hinge Cover) on the wireless switch works only when the system is
powered on. A user can activate the switch and have it scan for networks only
after going through a complete boot process. The switch is used to detect only
wireless signals. This setting is in the BIOS under the
Wireless section.
The LED indicates the following functionality:
Thank You,
Dell-Jesse L
Dell Social Media and Communities
SOURCE: I can't find out how to activate the "FN" keys. keyboard
1. Right Click on "My Computer" on the desktop.
2. Select Properties
3. Select Hardware
4. Select Hare ware Profiles
Find mouse in the list, double click...
Click Disable
Click OK
You are done!
SOURCE: KEYBOARD STUCK ON FN KEYS
Start the computer and go into Safe Mode by pressing the F8 key repeatedly when you see the Dell splash screen. Select Safe Mode at the top of the list. When SM is fully loaded, you will see a windows telling you that you are in SM. There will be two buttons at the bottom of the window. Click the right button to do a system restore. Choose a date just before the mishap with the external keypad. It will restore the computer to how it was at that time and restart Windows.
Good luck, and please let me know how it works out.
~ Spoem
SOURCE: Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
SOURCE: Latitude D600, how use FN key to have the numeric pad on
In the system setup (F2 at boot) look for Numlock settings, there should be an option to change the key combination for numlock
SOURCE: can't activate wifi key on inspiron 9400. fn f2
Try to uninstall then re-install the Dell Quickset from the Drivers and utilities disc.
