Microwave Ovens Logo
Posted on Apr 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung Microwave runs won't heat
The microwave turns on but won't heat up food
Ginko
Level 3:
  • Samsung Master 19,396 Answers
  • Posted on Apr 27, 2009
Ginko
Samsung Master
Level 3:
Answers
19396
Questions
25
Helped
8076554
Points
55462
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
  • sureedu Sep 04, 2010
    "Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person."
    Let this line of caution be in Red color and in Bold type!
    How to do the leak test?
    Best solution.
  • DROPNDEAL
    DROPNDEAL Jan 10, 2018
    This requires specialized tools and qualified technicians. Not a DIY job.
DROPNDEAL
Level 3:
Top Expert:
  • Samsung Master 2,931 Answers
  • Posted on Jan 10, 2018
DROPNDEAL
Samsung Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932226
Points
21770
If your current microwave is under warranty, pursue that route first. Otherwise, simply replace the non-functional unit with a new one including a warranty. At the time of this writing, Lowes has 1.7cuft Stainless units under $160. Take your old one down and reinstall a new one in an hour and be done with it.
Whirlpool 1 7 cu ft Over the Range Microwave and Speed Cook Stainless...
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13692
Points
Many Samsung Microwaves have a demonstartion mode retailers use to demonstrate the unit. It allows the unit to function but not heat. The demonstration mode can be turned on and off by holding the 0 while pressing the 1 to turn the demontation mode off and on. This happened to my mother's SMH9187W over the range during cleaning. It is where I would check first before troubleshooting electrical components.
5 Related Answers
Anonymous
  • 1214 Answers
  • Posted on Dec 11, 2009
SOURCE: Samsung microwave doesn't heat food.
Microwave ovens that do not heat, and failed as you have described, have 1 or more of the following failed components, in order of cost -
1) Fuse
2) Diode
3) Capacitor
4) Transformer
5) Magnetron
4 and 5 are interchangeable when it comes to cost.
Try replacing 1 and 2, then 3, then it's decision time of whether to buy parts or replace the microwave.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 31, 2007
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 19, 2008
SOURCE: Samsung MD800SC Microwave runs but stopped heating
Chances are you have a bad connection, maybe the cook relay or at the magnetron, but feel free to write back with details when it fails again.
Anonymous
  • Posted on Nov 09, 2008
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Feb 08, 2009
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
9 out of 10 times if all else is working then it is the magnatron rod that does the heating chances are it will be more expensive than to purchase a new microwave.
Microwave won't heat food at all
If it has a platter does it turn? (possible safety switch in the door issue) Other than that a Diode, inverter board (diode might be on it) or the Magnetron bad.
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
8helpful
2answers
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
1helpful
I have a samsung smh7177ste/be microwave that will not heat. Every thing seems to be working as normal
The problem is one of three things, the magnetron "common issue" or the high voltage capacitor and diode can be a factor, the above mentioned work together to heat food. Depending on the nature of the repair, parts and labor can run as high as a new microwave oven.
7helpful
2answers
The microwave will not heat food. It will turn on the turntable will go around and the time will count down but the food is not heated when done. tried different heat setting with no results.
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
4helpful
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
4helpful
1) Fuse
2) Diode
3) Capacitor
4) Transformer
5) Magnetron
1helpful
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
