Well if the fan isn't running then it's shutting off because of overheating obviously. You will need to put a new fan into your PS3. Taking apart a PS3 is very difficult so if you're going to do it yourself you'll need to find a tutorial on the internet. I believe the PS3 uses standard computer fans so you'll just need to buy one of the same size from a site like newegg.com. Once you put that in it should work, if it doesn't then there is something much more severe happening like a motherboard failure and if that is a case you will not be able to repair it.
Please rate, thanks!
I have exactly the same problem. will SONY repair this as a warranty of factory defect?
