Clarion DB245 CD Player Logo
A
Anonymous Posted on Feb 17, 2018
Wiring diagram Lots of different coloured wires, what colour relates to which feature. My guess is black is a earth wire as it connects to both the body of the unit and also the metal of the car, I also believe the yellow wire is a power feed as it has a fuse attached but what of al the remainder wires?
Gloria R. Bloomberg
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 86 Answers
  • Posted on Feb 17, 2018
Gloria R. Bloomberg
Expert
Level 2:
Passionate:
Answers
86
Questions
14
Helped
25601
Points
456
Black Wires is best ..
5 Related Answers
Anonymous
  • 132 Answers
  • Posted on Jan 03, 2008
SOURCE: wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Anonymous
  • 752 Answers
  • Posted on Aug 05, 2008
SOURCE: clarion marine stereo M2455
Don't worry about the brown wires. They are for telephone mute.
The yellow is Memory (constant 12 volt, so battery is fine), but the red should go to a 12 volt source that turns on and off with the key.
Anonymous
  • 67 Answers
  • Posted on Jan 29, 2009
SOURCE: Clarion DXZ785USB - Connecting Fused Lines
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Anonymous
  • 578 Answers
  • Posted on Jun 25, 2009
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Anonymous
  • 136 Answers
  • Posted on Sep 04, 2009
SOURCE: Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Testimonial: "Thanks that was GREAT!!!!"
Trying to find wiring diagram for engine for 2019 E450 Ford Jayco Red Hawk Motorhome
You can google it very hard to understand diagram 98% are not coloured coded example Jayco right side black earth white active left side black active white earth ???? This is my van trail and error!
Mar 05, 2019 • RVs
Do you know the colour of the indicator wire on a 59 plate vauxhall insignia please
Because of the light cluster, I guess it aint obvious. Pop out the side repeater holder on the wing and check the colours of the 2 wires there. Guessing one will be black (earth) and the other may be the colour you are after.
Vintage singer 3 pole plug wireing
WIRE WITH COLOUR GREEN OR WITH SOMETIMES GREEN WITH YELLOW STRIPE IS THE EARTH WHICH HAS TO THE TOP ONE USUALLY MARKED WITH AN ANTENNA SIGN UPSIDE DOWN. BROWN COLOUR WIRE IS USUALLY LIVE WHICH IS MARKED IN PLUG AS (L) AND BLUE COLOUR WIRE IS NEUTRAL USUALLY MARKED IN PLUG AS (N).
IN CASE THE COLOUR DIFFERS OR ELSE THE PLEASE INFORM SO THAT WE CAN REGUIDE YOU.
1helpful
Mains wiring for Belling Solitaire G707 gas cooker
Improve the FixYa experience for everyone by voting. I want you to let me know if the solutions suggested were of any value. Constructive criticism is welcomed.
I'm a Yank who has lived in Europe for ten years and am familiar with mains, earths and colour.
Here a couple of possibilities for you that will require a little work on your part.
CLICK HERE
for eSpares (UK), who assure me that they can help you out.
CLICK HERE for the patent diagram.
CLICK HERE for the non-English diagram.
This was a challenging question and I'm really interested in how you make out.
1helpful
Diagram for multi plug, elkavox 83 generater to accordion
one wire coloured red is connected to the live line(soldered)
second wire blue in colour is connected or soldered to the neutral line.
third wire coloured green and yellow is connected to the earth line.
Peavy 112 monitor,1 yellow and 1 blue wire going to speaker .Which is positive,and negative?Thanks:)
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #1a1a18}
The wire which is coloured and yellow must be connected to the terminal which is marked by the letter E, or by the earth symbol.
The wire which is coloured blue must be connected to the terminal which is marked with the letter N, or coloured black.
The Yellow coloured wire is going to be the positive, and the Blue wire is going to be negative wire.
Hi i got a red green and black wire cable and I
Partial solution. Rob's clarification request is very valid, and you shouldn't mess with electrics if you are not completely sure what you're doing. That said, my guess is that you are in Europe (possibly the UK). Confusion can be caused by relatively recent changes in colour codes, so older and newer wires are coloured differently. Basically, red and brown signify "live", black and blue signify "neutral" and green signifies "earth" (or "ground"). So if you are just joining these cables, red goes to brown, and black goes to blue. But what about the green...?  Some machines are designed to be earthed, others are designed to be not-earthed, and it's not clear to me why you have an earth wire in one cable and not in the other. If the green is in the cable that brings power in to the machine, then it should be fixed to some metal part of the machine It can be FATALLY dangerous if you fail to earth a machine that should be be earthed. I repeat, if you are not absolutely sure what you are doing, don't risk it. Anyway, post more details and it looks like there's at least two of us out here who can help you.
3helpful
2answers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
