Question about Necchi 6015 Mechanical Sewing Machine
Thread is gather up when sewing looks like a problem with the bobbin
SOURCE:
  • 3 Answers
SOURCE: needle picks up bobbin thread but then thread gets stuck
I've had similar problems (as well as other problem with the thread breaking all the time and the "shuttle race" thing that holds the bobbin falling out. One very important thing that isn't mentioned in the manual but that the salesman stressed is that you have to use only "Schmetz" brand needles. They are a tiny bit longer, but that makes all the difference in the world if your stitches are skipping. I forgot and used Singer needles and had horrible results.
Posted on Aug 16, 2007
  • 66 Answers
SOURCE: How do i thread the bobbin on my necchi 539
take out your bobbin and turn it the other way
Posted on Feb 03, 2009
louislevel_2
  • 374 Answers
SOURCE: thread clogs up bobbin and knots up thread on back side of fabric
hi there,
well, common problem when you didn't acquired right set up of tension and clean feed dog,bobbins,shuttle race.on figure right bobbins winding.d329aa1.jpgset up counter clokwise thread rotation, set dial tension on #3 to #4, dial stich to # 8 to #12
only on cotton fabrics,others fabrics such as silk..etc,gradually adjust tension fine the smoothest adjustment,
on fig,thread looping top side threading50302ec.jpg follow threading so you can have fine sewing.also clean under bobbins from chips fabric and dust.have a nice day,don't forget to rate my fix,ythanks a lot
Posted on May 16, 2009
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Posted on May 27, 2009
Zenqi
  • 208 Answers
SOURCE: not picking up bobbin thread
Make sure that the needle is inserted with the flat side to the back and that you are threading the machine correctly. Be sure to turn the handwheel counter-clockwise, from the top towards you.
Posted on Jun 19, 2009
Bobbin thread is gathering up under Neath
Sounds like birds nest or thread nests. HINT: When threading the top thread, ALWAYS have the presser foot in the RAISED position.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 09, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
My machine gathers thread in the bobbin and then the thread breaks off.
check the needle to see if it's damaged
some sewing machines gather thread in the bobbin area when the thread come off the thread take up lever
check the bobbin & bobbin area for burrs
Sep 23, 2010 | Singer Sewing Machines
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Oct 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Necchi 6015 Mechanical Sewing Machine Logo
23 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
