SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
SOURCE: oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
SOURCE: Hello, I have a couple year old brigs and
Check the oil level in the engine itself. Verify that your oil reservoir is full, then try again.
You may also want to refer to the owners manual for other trouble shooting tips. Click this link to go to your manual.
http://www.pressurewashersdirect.com/manuals/020244%20manual_2.pdf
And remember
Automatic Cool Down System
(Thermal Relief)
If you run the engine on your pressure washer for
3-5 minutes without pressing the trigger on the spray gun,
circulating water in the pump can reach temperatures
above 125°F.The system engages to cool the pump by
discharging the warm water onto the ground
SOURCE: after first use we ran out of gas and now pressure
There is most likely a valve that shuts off the fuel to the carberator, check and make sure this is in the correct direction. Once it is, check the choke, some of these have a manual choke, some have an auto. with either case make sure that when it is shut off that the furthest out butterfly valve is closed, this will make it draw in that extra gas when it is trying to start cold.
